There are three captured nuts on the bottom of the TC battery box, the center one is to hold clamps below the box, are the two outside nuts for rods which anchor the battery? And would anyone be able to post a picture here of what the upper battery cradle looks like?
Thanks, Bryan.
TC Battery Box
- Tim Jackson
Re: TC Battery Box
Yes, a couple of rods to secure a batten over the battery. Not sure waht was original, but this works.
FTFU has this suggestion:
https://cdn.shopify.com/s/files/1/0270/ ... 1652107280`
1946 TC0999 / XPAG 1638
restore note
restore note
Re: TC Battery Box
Tim, you must have great faith in the durability of the insulation on that wire running from one battery terminal to the other!
I like to run a large lead/acid battery. A 24 fits nicely, and the built in handle allows easier in/out with the bonnet in place. This battery has 650 cold cranking amps and works very nicely with the stock starter motor and voltage regulator and dynamo.
