Grease Nipple in Rear Axle Housing
rstarkweather
Post by rstarkweather » Thu Nov 14, 2024 7:39 am
I have a grease nipple tapped into the top of my axle housing (the axle housing itself, not the pumpkin). What could this be for? I removed the diff cover to drain and refill the rear axle, and found this little surprise.
Re: Grease Nipple in Rear Axle Housing
Post by Steve Simmons » Thu Nov 14, 2024 8:46 am
Maybe someone thought it would be easier to fill with an oil gun from underneath?
rstarkweather
Post by rstarkweather » Thu Nov 14, 2024 9:23 am
Steve:
That was my initial thought. Though it seems a lot harder than just getting one of those quart size gear oil pumps. But I also wanted to make sure I was not missing something.
Rick
Post by Duncan M » Thu Nov 14, 2024 12:36 pm
Unless it is actually a small vent /breather that has been added to the top side...
AbingdonNerd
Post by AbingdonNerd » Thu Nov 14, 2024 1:28 pm
I would think that someone added that as an extra vent - in case the small vent hole found on the fill plug became clogged.
If you examine the zerk fitting, it may be that the ball and spring have been removed - to allow easy venting.
