TC oil sump capacity
I'm close to starting my TC . A lot of chat about engine oil and capacity of sump . Enlighten me .
Re: TC oil sump capacity
6 Liter
cheers Carl
cheers Carl
If you have overhauled the engine you should use "Running in" oil. Try and run it in with a few long journeys and then drian nthe oil with the engine as hot as you can get it and fit a new filter.
Running in oil has more then normal ZDDP to protect new pistons and rings and white metal bearings.
More specific: What is sump capacity ? in U.S. quarts .
I believe 5.4 quarts U.S.
Be sure and prime the oil pump before you start it
