Post
by Steve Simmons » Sat Oct 22, 2016 11:58 pm
frenchblatter wrote:My BDR 7 (220 bhp) has the exhaust coming over the chassis rail, through the bonnet. The heat escapes out if the unwrapped pipes. I've never had a problem with fuel vapourisation
Sure, but your 7 is a completely different animal than a TC, even if it has carburetors instead of fuel injection. Try placing two SU carbs with external fuel bowls directly over the exhaust manifold. Now place the intake manifold between the header pipes. Next, place the fuel pump right behind and above the manifold. Then close up the bonnet tight around the engine to limit air flow. Now tell me some exhaust insulation won't help! If nothing else, the air going into the carbs will be 20-degrees cooler. Not that wrap is a necessity on a TC, but in this type of car it does help in certain situations. I've seen ceramic coating completely cure vapor lock on more than one TC locally. Our climate can get quite hot though.
My supercharged '67 has the carb sitting about an inch over the rear header pipe. That one pipe is wrapped to help prevent vaporization, cool intake air and keep me from burning my hands when tuning! It was actually placed there by the builder / dyno guy.
Post
by frenchblatter » Sun Oct 23, 2016 2:07 am
Steve, my 7 has carbs, 2 weber 45s.
The point I make is that if you wrap the downpipe in heat insulating material where do you think the heat goes. Well it goes down the pipe and radiates off the unwrapped portion of the pipes. It also goes back into the engine and heats the exhaust port and exhaust valve.
The fact is the head, on the exhaust side will be hottor with wrapping than without. It can cause a problem but maybe not. I have fitted two insulation blocks between carbs and manifold.
Post
by stephen stierman » Mon Oct 24, 2016 3:00 am
Sorry, I don't buy it. As I mentioned the head pipes on my Plus 8 have been wrapped for 25,000 miles without issue. What about all those ceramic coated manifolds? Are they different from header wrap? Jaguar used to coat all the XK manifolds, so did many others. Because somebody says so, doesn't mean it is true. Is there a thermal engineer in this group that can show us some real data, not he said she said?
Post
by Marv » Mon Oct 24, 2016 4:21 am
"Ditto!" I'd like to see some empirical data to back up the words as well! Otherwise, this horse has been pretty much beaten to death!
SteveW
Post
by SteveW » Mon Oct 24, 2016 6:53 am
Heat only flows from hot places to cold places. It does this by convection, conduction and radiation. This is basic physics and anyone who thinks otherwise should let me know as I have a perpetual motion machine that I would like to sell them.
If the exhaust manifold is hotter than the head then heat can flow from the manifold to the head via conduction through the metal. It will do this whether or not its insulated unless you insulate the manifold from the head somehow. Insulating the manifold stops the heat radiating to other parts of the engine bay that its not in direct contact with and is there to stop petrol evaporation and to keep the intake air cooler so you get more expansion in the cylinder on ignition.
Sorry - I probably shouldn't be perpetuating this thread!!
Herman 5560
Post
by Herman 5560 » Mon Feb 13, 2017 8:12 am
Took a bit of a sabbatical on the restoration. Took on some building around the garage to create some additional storage so the garden tools can be moved out of the garage and at the same time move the compressor as it is taking up prime space due to its size.
My bodyshop man told me that the fuel tank is basically beyond the point of any repairs.
I do not have the money right now to import a new tank, but have two alternatives...
1) Cut the tank open at the back and fabricate a smalles stainless steel tank and fit it inside the original tank or
2) Fabricate a SS tank to fit into the space in front of the diff, both sides of the drive shaft. Would give me about a 30L tank.
What does the forum think?
Post
by Steve Simmons » Mon Feb 13, 2017 10:47 am
Hard to believe it's so bad that it can't be saved. If that's really the case, I suppose you could manufacture a new tank to fit inside as you described. Just use the remnants of the original tank to hide the new one. Not my first choice but it would work.
Herman 5560
Post
by Herman 5560 » Tue Feb 14, 2017 2:25 am
Anybody on here ever made their own fuel tank from scratch. Ofcoarse using brackets ans filler neck from old tank
Herman 5560
Post
by Herman 5560 » Wed Feb 15, 2017 10:26 am
I do not have any of the cables, Start, Choke and Fast idle.
Can somebody help me with pics and dimension so I can get our local cableman make them up for me.
Herman 5560
Post
by Herman 5560 » Fri Feb 17, 2017 12:18 am
This is the only pic I can get after hours of surfing. Is the inner a single wire or a cable made up of a lot of thin wires? Is it the standard that this cable must be turned to lock the choke in place?
![images(4).jpg](./download/file.php?id=895&sid=199aa9ee407bda26a7d54822b3f499d2)
- images(4).jpg (4.92 KiB) Viewed 8705 times
dirk w dondorp
Post
by dirk w dondorp » Fri Feb 17, 2017 12:54 am
single-so called pianowire (over here) and turned to lock (choke) Think are all available at T parts suppliers UK and USA
Post
by Steve Simmons » Sat Feb 18, 2017 11:51 am
Choke and starter are both stranded wire. The knob is a small, simple one without markings.
![Moss TC Starter and Choke Knob](./download/file.php?id=898&sid=199aa9ee407bda26a7d54822b3f499d2)
- Moss TC Starter and Choke Knob
- dash-knob.jpg (53.05 KiB) Viewed 8684 times
Herman 5560
Post
by Herman 5560 » Sun Feb 19, 2017 10:01 am
Approximate length?.
Post
by Steve Simmons » Mon Feb 20, 2017 10:13 am
From the end of the threads, 57" for the housing and 67" for the cable. This is a Moss reproduction.
Herman 5560
Post
by Herman 5560 » Wed Feb 22, 2017 2:39 am
Spent the week end re producing the steel behind the dash and A Pillars. I order not to destroy the door fitment I had to hang the doors. for easy access ito the car I folded the Lh door all the way round...180 Deg.
I know the wood in my car is in a terrible state...but that is a future project.
This did not look right so I looked up and found there should be a "Door Check" to prevent this. Also found it in all the catalogs ...once I knew what to look for.
some picks please of how and where this is fitted. Looks pretty easy to re manufacture so some sizes will not be bad
![Very Happy :D](./images/smilies/icon_mrgreen.gif)
to facilitate the process.
![Lh Dasg Support Steel.jpg (387.42 KiB) Viewed 8655 times Lh Dasg Support Steel.jpg](./download/file.php?id=903&t=1&sid=199aa9ee407bda26a7d54822b3f499d2)
![Tc Check Strap.jpg (20.49 KiB) Viewed 8655 times Tc Check Strap.jpg](./download/file.php?id=904&t=1&sid=199aa9ee407bda26a7d54822b3f499d2)
Herman 5560
Post
by Herman 5560 » Sat Feb 25, 2017 1:40 am
Nothing mentioned in TC FE, but had a good look at my doors and tub.
There are some holes in the metal cladding, but nothing in the wood. Could this be where the "Door Check" should be fitted?
Does the hinge side go onto the Tub? The hole in the door is much larger than the one on the tub side
![Door Check holes door S.jpg (223.2 KiB) Viewed 8643 times Door Check holes door S.jpg](./download/file.php?id=905&t=1&sid=199aa9ee407bda26a7d54822b3f499d2)
![Door Check Holes Tub S.jpg (318.99 KiB) Viewed 8643 times Door Check Holes Tub S.jpg](./download/file.php?id=906&t=1&sid=199aa9ee407bda26a7d54822b3f499d2)
cdrolshagen
Post
by cdrolshagen » Mon Feb 27, 2017 1:28 am
Hello Herman,
attached pictures may answer you question what is behind the hole in the door post.
If you send me a PM with your email adress than I give you acess to 600 pictures of a TC restauration process,
cheers Carl
![IMGP1628.JPG](./download/file.php?id=907&sid=199aa9ee407bda26a7d54822b3f499d2)
- IMGP1628.JPG (170.87 KiB) Viewed 8615 times
![IMGP1805.JPG](./download/file.php?id=908&sid=199aa9ee407bda26a7d54822b3f499d2)
- IMGP1805.JPG (99.27 KiB) Viewed 8615 times
![IMGP1716.JPG](./download/file.php?id=909&sid=199aa9ee407bda26a7d54822b3f499d2)
- IMGP1716.JPG (144.56 KiB) Viewed 8615 times
Herman 5560
Post
by Herman 5560 » Mon Feb 27, 2017 2:23 am
Thanks Carl...Done
Back to the Door Stay...
If somebody can give me a few dimensions.
I have found an App the week end that will scale directly from a .jpg file, if you just have a reference dimension.
Is the threaded part a 1/4 or 5/16 bolt? On Carl's car it can also be a 7/16 bolt. The rest I can calculate if I also know how far open does this part make your door go.
cdrolshagen
Post
by cdrolshagen » Mon Feb 27, 2017 2:45 am
Hi Herman,
it is 1/4 Inch
for the measurments give me some hours - I think I still have the original Door Post
cdrolshagen
