TC carb linkage
TC carb linkage
Post by antijam » Mon Sep 04, 2017 2:10 am
Re-assembling my carburettors to the engine after rebuild I notice that the jet lever long arms and the cable bracket have all been cranked down to nearer a vertical position on the car. The fact that the degree of bend is different for each leads me to suspect that this is not an original feature but has been done at some time in the car's history. The engine is out of the car so I can't check if this has been done clear some obstruction, but perhaps someone can tell me if the two levers and the cable bracket should normally be flat and un-cranked?
These piccies I hope illustrate the problem..
View from front
View from rear
In both views the front lever is arrowed green, the rear lever red and the cable bracket yellow.
Re: TC carb linkage
Post by frenchblatter » Mon Sep 04, 2017 1:22 pm
The bracket looks wrong but could be the camera angle.
Look at this, it's the correct bracket, cable and arms: http://www.lotus7news.co.uk/TC03-17a%20(1).jpeg
Re: TC carb linkage
Post by frenchblatter » Mon Sep 04, 2017 1:32 pm
or a better view look at 17th March on this page: http://www.lotus7news.co.uk/MG-TC-MAR16.html
take time to adjust the connecting rod between the arms. Fit one end and then adjust the ends so they are both "lose" when the cable is in. It's too easy for the rod to be too short or too long which will keep one jet down when the cable is in.
Re: TC carb linkage
Post by antijam » Tue Sep 05, 2017 12:47 am
Thanks for the links, but I can't see any pics that show whether or not the cable bracket and the long arms of the jet levers are cranked inwards towards the block?
Re: TC carb linkage
Post by Marv » Tue Sep 05, 2017 6:06 am
Ask Joe Curto to weigh in on it. Or Doug Pelton.. Lots of experts out there.....
Re: TC carb linkage
Post by frenchblatter » Tue Sep 05, 2017 6:12 am
The arms and bracket are straight and have no sideways bend in them.
Re: TC carb linkage
Post by antijam » Tue Sep 05, 2017 10:01 am
frenchblatter wrote:The arms and bracket are straight and have no sideways bend in them.
Thanks.
Re: TC carb linkage
Post by frenchblatter » Tue Sep 05, 2017 8:58 pm
Her's a few pictures, not the easiest item to photograph from the end on angle.
http://www.lotus7news.co.uk/db_09_17.htm
Scroll down to te 5th September
Re: TC carb linkage
Post by antijam » Wed Sep 06, 2017 1:19 am
Thanks again - just the shots I needed.
