Rear spring top plate - removal
Before I wreck something... is it advisable to remove the rear spring top plate, or, if the threads are in good shape, leave it alone? Is this riveted to the rear axle?
Mitch
1948 MG TC Special
1958 MGA
1948 MG TC Special
1958 MGA
Re: Rear spring top plate - removal
That spring plate and stud assembly (item 7) should come off with a sharp rap with a hammer and punch. I suspect that it is held in place from road grime only unless the PO welded it in place for some god-awful reason. The spring plate ass'y is attached to the rear road spring prior to ass'y to the rear axle housing.
What Marv said. A good drawing here:
http://mg-parts-spares.co.uk/parts-cata ... sion-axle/
5 Lb hammer and a chisel!
Good enough. It'll come off then. I was afraid I was going to go to battle with a rivet.
Mitch
1948 MG TC Special
1958 MGA
1948 MG TC Special
1958 MGA
