Nuts and bolts
- timandgerda
Nuts and bolts
Evening all. Does anyone know the correct bolts for fitting the handbrake brackets to the chassis? When looking through the bits I got with the car I have found four 5/16 BSF bolts 1" long that have locking nuts and are drill for split pins - any idea what these are for? Thanks. Tim.
Re: Nuts and bolts
Sounds like typical hardware used on the driveshaft to flanges.
- Tim Jackson
Re: Nuts and bolts
Agree with Duncan, could be prop shaft. The handbrake is secured with four BSF 5/16 in x 3/4 in nuts/bolts, according to this TC list of body and chassis bolts (page 2). I don’t recall any chassis fasteners with castellated nuts/split pins.
- TC body & chassis bolts.pdf
- (456.07 KiB) Downloaded 249 times
1946 TC0999 / XPAG 1638
restore note
restore note
- timandgerda
Re: Nuts and bolts
Thanks guys - that's great.
