Manifold studs
Mark Robinson
Manifold studs
Post by Mark Robinson » Sun Sep 23, 2018 4:47 am
Should I be screwing the longer end or the shorter end of the manifold studs into the block? Thank you.
Regards
Mark
TC4157
Re: Manifold studs
Post by Tom Lange, MGT Repair » Mon Sep 24, 2018 1:06 pm
Niether - if you mean the long studs to hold both instake and exhaust manifolds, the shorter end goes into the head, not the block. The short end of a stud goes into the permanent part - the short end of the head studs go into the block, the short end of the exhaust manifold studs go into the exhaust manifold flange, and the short end of the valve cover studs goes into the head.
Mark Robinson
Re: Manifold studs
Post by Mark Robinson » Tue Sep 25, 2018 1:17 am
Hi Tom. Yes I meant to say head rather than block. That's really helpful, many thanks.
Regards
Mark
