Volumex supercharger capacity (air movement)
Mitchman2
Post by Mitchman2 » Wed Jun 05, 2019 12:19 pm
Does anyone know the volume of air the volumex 7 rib outputs per revolution?
Stamped FAIT and 0011.
Volumex Super.jpg (29.77 KiB) Viewed 1873 times
Mitch
1948 MG TC Special
1958 MGA
cdrolshagen
Re: Volumex supercharger capacity (air movement)
Post by cdrolshagen » Wed Jun 05, 2019 10:40 pm
Hi Mitch,
1,15 Liter
cheers Carl
Mitchman2
Post by Mitchman2 » Fri Jun 07, 2019 5:14 am
So, I'm going to embarrass myself here a bit...
Per revolution a 1250cc engine will gulp 625cc (2 power strokes) and the blower outputs 1150cc. That's almost a 2:1 ratio, blower capacity to engine capacity.
Normal atmospheric pressure (at sea level) is approx 14 psi. So I should expect to see nearly 14 pounds on the gauge when the engine is running, correct? That seems like a lot. I've been told to expect 5 to 6 psi.
Mitch
1948 MG TC Special
1958 MGA
