Rod Letcher
Post
by Rod Letcher » Sun Jun 23, 2019 9:57 am
What book or manual would you guys recommend for a newby with a TA
Rod
Rod
http://www.customfurniture.net/
1913 Ford Model T Speedster
1931 Ford Model A Deluxe Roadster
1938 MG TA
1952 Jaguar XK120 FHC
1957 Ford Thunderbird
1992 Chevy Silverado stepside PU (bought new)
Post
by Steve Simmons » Sun Jun 23, 2019 10:16 am
The best workshop manual I know of for TA is the Bentley Workshop Manual. It contains factory info covering all technical aspects of pre-war through TF. There should also be good TA content in "Original T-Series" by Anders Clausager, and possibly in "The T Series Handbook" put out by NEMGTR.
Post
by Tom Lange, MGT Repair » Sun Jun 23, 2019 11:54 am
The Bentley may be the same, but I find the Blower manual to be the most useful for pre-war cars. Also, go through Totally T-Type 2 back issues (all on-line), and make note of TA-specific articles. Things like TC-steering articles will be of great use as the TC is basically the same as TA, except for small differences.
Post
by Steve Simmons » Sun Jun 23, 2019 12:02 pm
You're correct, Bentley and Blower are the same thing. I believe Bentley is simply the newer owners of the book.
Rod Letcher
Post
by Rod Letcher » Wed Jun 26, 2019 3:53 pm
I bought this book, is it the one you were referencing? it seems a bit light on TA info.
Rod
Rod
1938 MG TA
Post
by bloodysalmon » Wed Jun 26, 2019 11:11 pm
Hi Rod, it really depends on where your thirst for knowledge is needed; a copy of the TA Manual (sold by the Octagon CC here in UK) will give you all what MG wrote about the TA; TA parts manual will also clarify what parts where fitted (and description) to the TA. There's little about the TA engine which is different to the TB and TC being XPAG. So if your after body reference and general but excellent reference to how a T-type goes together then you cant go wrong with Mike Sherrills 'TC's Forever' ... not cheap but an absolute bible, also supplemented by his latest green version too.
So depends on how original your TA may be and how and what you wish to do with the 'originality', restore, replace, leave and or modify. Perhaps reading more about a TA will actually help decide which way you'll then go too.
![Wink ;)](./images/smilies/icon_wink.gif)
Rod Letcher
Post
by Rod Letcher » Thu Jun 27, 2019 1:35 pm
Guy's, Thanks for the responses, they are much appreciated. So far I have got 2 books, I'm not sure if the Bently book (the black one) is the same one recommended by Steve?
![213-785_1.jpg (150.64 KiB) Viewed 3097 times 213-785_1.jpg](./download/file.php?id=1538&t=1&sid=118fcfd4a3a6ddf7aeea559ccbccf107)
![s-l1600.jpg (286.76 KiB) Viewed 3097 times s-l1600.jpg](./download/file.php?id=1539&t=1&sid=118fcfd4a3a6ddf7aeea559ccbccf107)
Rod
1938 MG TA
Bill Davis
Post
by Bill Davis » Thu Jun 27, 2019 1:35 pm
Rod,
In addition to those books Chris and others have listed I’d suggest a copy of ‘Tuning and Maintenance of M.G.s’ by Philip H. Smith.
And yes, most books you find are indeed going to be “a bit light on TA info.”
Good luck and happy reading.
Bill - TA2190
