TC carb spindles alignment
Re: TC carb spindles alignment
I bet if the shaft was a bit longer so it could go through all the holes in the springs, it would line up better.
Excellent! I'll make a new longer one. It's amazing what one finds. Cooling Fan was also installed backwards! Thermostat had no thermostat, etc.
Turning the fan around should make a huge difference in traffic! My car doesn't have a thermostat either. It does tend to run way too cold in frigid weather, so I have to cover the radiator in those conditions. One of these days I'll bite the bullet and just put a thermostat back in the thing. Better to run too cold on rare occasion than have an overheating issue though. It runs cool even in triple digit temperatures.
- timandgerda
Hi Guys. My carb spindles looks just like yours but I read that the W clips should be at 90 degrees to each other to allow for slight misalignment. Anybody know for sure?
Good point. I did mine 90 degrees.
