The steering on my TC is very sloppy and is feels stiff to turn. I know these cars are known for heavy steering but this is more stiff than heavy. I have adjusted all the track rods, changed one wheel bearing and one king pin so there is no undue play anywhere in the front hubs however there is about 3" of play at the steering wheel.
So being used to adjusting steering boxes ( I also have an air cooled beetle) I though a quick twiddle and away I go .........wrong! When I turn the adjuster to take out the play all that happens is that the steering gets even tighter. So time to take off the steering box cover to have a look. What I can see looks very wrong to me, in the middle of the sector shaft is a sunken ball bearing which rubs against the middle of the adjuster stopping the thrust races even touching their mating surfaces. I have had a look Brown and Gammons site which has Tomkins fitting instructions and there is no mention of the ball bearing.
I think if I take out the ball and remove the burrs it has made I will be able to adjust the box as it should be.
Has anyone got any experience of this ?
Once again thank you for any help
