TC generator front plate
Can the front plate on a TC generator be successfully welded? The mounting hole on mine is very worn so needs to be repaired. I am not sure if the plate is steel or cast iron. If it is cast I will have to braze it up.
- Gene Gillam
Re: TC generator front plate
Max,
Pretty sure it's cast, just like most of the engine.
Gene
Gene
