Ford T-9 transmission fluid
Post by Gene Gillam » Sun Sep 08, 2019 1:50 pm
What is an acceptable type of fluid to use in the T-9 transmission that can be found here in the States?
Thanks,
Gene
Re: Ford T-9 transmission fluid
Post by Steve Simmons » Mon Sep 09, 2019 10:53 am
I seem to remember 90W, which would mean 75W-90. Any yellow metal safe gear oil should do the job nicely.
Richard Michell
Post by Richard Michell » Tue Sep 10, 2019 2:31 am
It appears that the T9 requires a GL-4 gear oil, not GL-5. I am in Australia so not much help re US supply but Redline MT-90 75W90 GL-4 GEAR OIL is probably available (at a price!). There would be cheaper equivalents I would guess.
Mitchman2
Post by Mitchman2 » Wed Sep 11, 2019 5:37 pm
Hi-Gear shipped 2 qts with my trans to make sure the correct type was used. They shipped SX75W-90 GL-4, Semi Synthetic.
Mitch
1948 MG TC Special
1958 MGA
Post by Ray White » Thu Sep 12, 2019 12:21 pm
Mitchman2 wrote:Hi-Gear shipped 2 qts with my trans to make sure the correct type was used. They shipped SX75W-90 GL-4, Semi Synthetic.
That is the same as supplied with my T9 box which I collected from Peter Gamble (Hi-Gear) this week.
