MG TA sump drain washer
- martinjames
Having difficulty finding a correct size copper washer for the TA sump drain plug. NTG in the UK have them for GBP1.89 but want GBP25 freight to NZ!! Have tried locally but haven't found one large enough yet.
Re: MG TA sump drain washer
Worst case you could cut one yourself from Cooper sheet.
hello,
try your local plumber,
cheers Carl
cheers Carl
Recycle the old one.
Hello
i searched for a magnetic sump plug and found this in the description
BRASS GEARBOX PLUG WITH MAGNET & FIBRE WASHER. THE ORIGINALS WERE
MADE FROM SOFTER BRASS, AND MOST ARE PRETTY CHEWED UP BY NOW!
is it possible to take modern material ?
Is it advantageous to use magnetic types?
- ROGER FURNEAUX
I make these drain plugs with magnet, and sell them on eBay. They come with a hard fibre washer;
Roger
Roger
Hello
i have asked for all three, but don t get answer.
Shipping to germany on ebay is always so expensive ;-(
