Inside fit rear arch wood to wheel well
Mark McCombs
Post by Mark McCombs » Sun Jun 21, 2020 5:40 am
Back when I bought TC8126, I knew zero about the TC tub construction and woodwork. At that time, I followed TC's Forever advice regarding original wood, in that if any original wood was in good shape, to reuse it; Nice to have original factory wood if possible, too.
I replaced all my tub wood except both rear top wheel arch pieces and the piece it fits to (rear side rail and elbow piece).
I figured too that it was good to have this original shape, which would naturally fit my original rear wheel wells, which they do. I carefully drilled and dowel plugged any original holes so to have fresh wood for new screws before I installed the rear wheel wells.
Curious tho why the factory cut a taper on the bottom inside edge of the top rail pieces, as the rear wheel wells are a flat fit against the bottom of the rear rails at this intersection. I can only speculate there may have been an insulation pad on top of the inside wheel well area (under the vinyl cover) that extended under this inside taper, maybe to prevent body noise, allow for body flexing, or ?. Anyone have any thoughts on this? I dont think replacement wood sources include this taper cut.
Also to this, there is a pad or cut insulation that covers the inside of the rear wheel wells under the wheel well vinyl cover, correct?
Mark Strang
Re: Inside fit rear arch wood to wheel well
Post by Mark Strang » Wed Jun 24, 2020 6:04 pm
I don't know why the taper is there but there is a pad under the wheel well cover. It is thicker than the taper to steel gap. I generally just apply some seam sealer between the steel and the wood to seal it up. Works fine to fill the gap.
Mark McCombs
Post by Mark McCombs » Thu Jun 25, 2020 1:07 pm
Thanks, Mark-
It is interesting for sure, and I would like to think it was there for some reason.
I was thinking in line with your comments, with the felt pad extending the 1/2" or so into that taper gap. I guess it cant be 'wrong' if its my original wood!
Mark Strang
Post by Mark Strang » Thu Jun 25, 2020 5:32 pm
My TC tub was built by Fenton Bagley. It is a copy of what came out of the 'Works' and is very accurate. Fenton did really good work and was basically an artist with wood and metal. TC7801 is a stalled project(20 years) that I picked up a couple of years ago to restore. I'm in the primer stage now and the gap is there. I filled it.
