Abingdon Performance Ltd
Permanent offers and vendor advertisements.
Customer satisfaction is requested
1) Quality of materials
0
No votes
2) Performance of parts purchased
0
No votes
Total votes: 0
laf48@aol.com
Post by laf48@aol.com » Sat May 28, 2022 4:42 am
Here is a list of what I offer:
Crane, now Comp Cams Roller tappet camshaft kits: Stock replacement, street performance, S/C or normally aspirated as well as race cams. includes, steel billet Roller cam, roller lifters, HD Chrome Moly push rods, " Super clean wire" CNC coiled,stress relieved, shot peened, & heat set valve springs,alloy steel spring retainers & lower locators. $1995. Roller cams will outperform any flat lifter cam of the same duration, with a wider power band.
Harland Sharp roller rocker arms, $ 525 per set, includes socket head pedestal bolts with high collar lock washers.
CSI ignition distributor dealer, all MG units in stock. https://csi-ignition.com/ MG t type $ 430. MGA/MGB $410. Many other make also in stock.
Custom Swirl polished Stainless-steel 37 & 35 mm valves with manganese bronze guides and cotters $ 295.
Teflon Positive stop valve stem seals $ 38.
And more :)
All my products are Unconditionally guaranteed
Roller camshafts are a period correct up grade.
Len Fanelli
laf48@aol.com,abingdonperforma@aol.com
914-420-8699
The last camshaft your car will ever need
roller cam kit jewelry.jpg (53.43 KiB) Viewed 29056 times
16 programable advance curves
Custom high flow valves
swirl polished valve w guite.jpg (30.13 KiB) Viewed 29056 times
Custom Teflon valve stem seals
positive stop valve stem seal.jpg (11.96 KiB) Viewed 29056 times
Last bumped by laf48@aol.com on Sat May 28, 2022 4:42 am.
