I'm building up a TF block and noticed that the distributor clamping method is different from the earlier TC/TD engines I'm used to.
Can someone post a photo of the clamp/bolt - would like to see one mounted (in use) and one laying on a bench.
Is it something that can be made fairly easily? Or does anyone have a spare they're willing to part with before I go hit the usual suspects?
Thanks in advance...
Gene
TF Engine Block Distributor Clamping Bolt
Re: TF Engine Block Distributor Clamping Bolt
Found what I need...thanks!
