MGTC tires
Bob Brown
MGTC tires
Post by Bob Brown » Wed Nov 13, 2013 9:59 am
I am finally going to bite the bullet and replace my "very old" dunlop tires on my TC so am am looking for recommendations on sources for replacement tires. Checked out Blockley tires but the shipping to Miane might be a deal breaker. Appreciate any help in making a selection...Thanks
Re: MGTC tires
Post by stephen stierman » Wed Nov 13, 2013 10:36 am
I have been using the standard Excelsiors from Coker and find them to be fine for my needs of general running around, they also look very similar to the Dunlops. They have about 6K on them and seem to be wearing well. Given they are bias plys, I would not expect 30 or 40K life span though.
Re: MGTC tires
Post by Steve Simmons » Thu Nov 14, 2013 12:08 pm
I have little experience with different tires, but have been very happy with my Dunlop B5 as originally fitted. Handling is good although they do wander a little on grooved concrete. You can get a softer ride with Firestones or similar.
Henry Pang
Re: MGTC tires
Post by Henry Pang » Thu Nov 14, 2013 8:01 pm
Hi Mr. Brown,
You may want to check out Lucas Classic Tires ( https://www.lucasclassictires.com ). They have the 400x19 Blockley for $171 + shipping. You may talk to the East cost shop, shipping cost may be must better from there. I have my TC fitted with 5 Blockley, and it's great (see picture). Made sure you have it balance and check the Toe-In (1/4 in) with a good shop. It will last you another 10 t 20 years.
Henry Pang
TC7784, Washington
olson_gene
Re: MGTC tires
Post by olson_gene » Thu Nov 14, 2013 10:55 pm
Henry Pang wrote:You may want to check out Lucas Classic Tires ( https://www.lucasclassictires.com ). They have the 400x19 Blockley for $171 + shipping. It will last you another 10 t 20 years.
How long tires last depends on driving. I have worn out Blockleys in 3 years ( maybe 8000 miles). But I drive the TC pretty hard.
Gene Olson
Simi Valley
Southern California
Bob Brown
Re: MGTC tires
Post by Bob Brown » Fri Nov 15, 2013 12:56 pm
Henry,
I notice you were using the 400X19 but I thought the TC used 450's.
Bob
Henry Pang
Re: MGTC tires
Post by Henry Pang » Sat Nov 16, 2013 11:16 am
Hi Mr. Brown,
I have the 450x19 Blockley.
Henry Pang
TC7784, Washington
bar20
Re: MGTC tires
Post by bar20 » Fri Mar 07, 2014 9:34 pm
Check with Coker, Lucas and others to see if they are doing any swap meets in your area. Coker was doing the Portland, OR swap meet and I ordered a set of tires and tubes and picked them up at the meet with no shipping charge.
48 TC
