machining the TC oil pump
Norman Golm
Post by Norman Golm » Wed Jun 25, 2014 7:54 am
I need to surface of the oil pump housing, cover and gears. I have had the parts to three shops and they don't seem to know how to hold the parts on a surface grinder. The surfaces are too rough to use the glass and sandpaper method. Is there another way of surfacing these parts? Or is there someone I can send the parts to?
Norman Golm
12158 N Foxview Dr
Northport, Mi., USA
ncgolm@gmail.com
Stan Teitge
Re: machining the TC oil pump
Post by Stan Teitge » Wed Jun 25, 2014 12:21 pm
Have you tried a machine shop with a milling machine. It will get the surface perfectly flat and then you could do the glass and emery trick.
Stan
Post by Steve Simmons » Thu Jun 26, 2014 8:51 am
Send them to Butch Taras. He rebuilds pumps and does it properly. Uses a surface grinder and gets everything to proper clearance.
Roland “Butch” Taras
3733 Fourth Ave.
Glendale, CA. 91214
USA
Telephone / Fax +1 818-249-9031
mgyowner@yahoo.com
Norman Golm
Post by Norman Golm » Fri Jun 27, 2014 4:03 pm
Finally found a journey men tool maker and had it done right.
Norman Golm
12158 N Foxview Dr
Northport, Mi., USA
ncgolm@gmail.com
