Build date
Build date
How do I know the exact build date for TC 9608 XPAC 10,315 late 1949. Has all plates and tags etc..
Thanks, Bent
Thanks, Bent
- Bill Ritson
Re: Build date
John James' website, (ttypes.org/ttt2/) has a T type database. It puts your car at 8/9 September 1949. There are no surviving factory records.
- Henry Pang
Re: Build date
Here is your build date. You can go to http://www.tregister.org for more information.
Henry,
TC7784
Washington
Henry,
TC7784
Washington
- TC9608.JPG (33.79 KiB) Viewed 4046 times
Re: Build date
Does anyone know if that date gives month first or date first, i.e., 06-09-1949 could be June 9th, 1949 or 6 Sept 1949. Aren't the British a 180 degrees out from the USA when giving dates?
Re: Build date
Yes, it should translate to the 6th of September.
Re: Build date
Gene, it is the USA who are 180degrees out. After all our way goes from the smallest to the largest, day/month/year which is surely the logical way to do it?
Regards
Ian Thomson
Notts. UK
Regards
Ian Thomson
Notts. UK
Re: Build date
That is pretty damn logical, Ian!
