Hi Peter- Question- How does one get the rubber bushings into the shock arm and the link base? I have to replace the link, which disappeared during the fall color tour, and the bushings are larger than the end of the link. Does it take 2 bushings at the arm and 2 bushings at the link base? These bushings I got from Moss are 1" OD x 3/8" id (hole) and 5/8" thick. The base is 1 3/16" thick and 7/8" dia. What special tricks to get 1" DO bushing into 7/8" id link base? Did you receive the Firestone tire data I sent?
John Patterson TC 7025
Re: 4.50 x 19 tubes for TA,B,Cs
- JOHN PATTERSON-TC 7025
