TA Air cleaner mounting
martinjames
Post by martinjames » Wed Nov 04, 2015 1:24 am
My TA came with two pancake air filters bolted on. I have purchased a new original format canister air cleaner and manifold, but there does not appear to be any way I can attach the manifold to the carbs as there are no attachment points on the manifold. Is there a part that goes between the manifold and the carbs as I cant find one in any parts catalogue?
mgtamike
Re: TA Air cleaner mounting
Post by mgtamike » Sun Nov 08, 2015 6:55 am
I think you mean the red bar in the photos. Goes between the inlet manifold and the air intake.
Its made of 3/4 by 1/8 mild steel. The close up shows the slow running cable terminated on the fixing bolt
martinjames
Post by martinjames » Wed Mar 02, 2016 11:00 am
Thanks. Photos were a great help. Have managed to buy a set of the correct HV3 carbs.
