Timing a Pertronix
Ed Stanfield
Timing a Pertronix
Post by Ed Stanfield » Thu Jan 17, 2013 2:46 pm
Some advice on timing an XPAG engine with a Pertronix negative ground system?
Thanks
Ed Stanfield
TD/20709
Re: Timing a Pertronix
Post by Gene Gillam » Thu Jan 17, 2013 5:01 pm
Ed, I've always timed mine as I would an XPAG with points. If I remember correctly it's set 30 degrees BTDC at 3000rpm.
distributorguy
Post by distributorguy » Mon Jan 21, 2013 7:28 pm
Set the crank to roughly 10 degrees BTDC
pull out the #1 spark plug, reattach the plug wire to it, and ground it to the engine.
Loosen the distributor clamp
Turn on the ignition power
rotate the distributor clockwise until the plug fires
Lock down the clamp
start and time the car with a dial-back timing light to verify about 35 degrees total timing
