TC top frame needed
Ed Dunn
TC top frame needed
Post by Ed Dunn » Wed Feb 09, 2000 7:56 am
I need a top frame (hood frame) for my early TC (#TC 0275) Also need front two side curtain frames.
Thanks.
Ed Dunn
eedunn@home.com
800-290-3751
Geoffrey WHEATLEY
Re: TC top frame needed
Post by Geoffrey WHEATLEY » Wed Feb 09, 2000 11:32 am
Try Brown and Gammon in the UK they are your best bet, helped me with my very early 45 TC. Do you have the original frame or any thing of it like the metal struts? If so you can get a replacement made...Side curtains are another matter!
Regards Geoff
JohnHWSteedman@aol.com
Post by JohnHWSteedman@aol.com » Thu Feb 10, 2000 4:57 am
I can't supply you with a frame, but I have an unrestored one from TC0301, which I am happy to measure, etc. if you need dimensions. As you will know from Sherrel's book, early frames have some unique characteristics, as do several other components, - I have still to find a scuttle that looks like mine (the tool box and battery box are spot welded into the rest of the scuttle, which I assume is a TB leftover); although you can see the same construction in the photo on page 45 Graham Robson's "The T Series MG" (if you have sharp eyes!)
regards,
John Steedman
