Differential oil
Differential oil
Post by jddevel » Fri Nov 13, 2020 6:32 am
What do you use in your differential. Any votes for Millers Classic Differential Oil EP 90 GL5
Re: Differential oil
Post by Steve Simmons » Fri Nov 13, 2020 8:39 am
I've been using Royal Purple 85W-140 for many years. No experience with Millers.
Post by Duncan M » Fri Nov 13, 2020 12:30 pm
When I replaced pinion bearings I used SKF bronze caged (not tapered conversion) and filled it with (Chevron) Delo Gear ESI 85W140. Oil like this is not marketed to classic car owners. Auto Zone always seems to have it.
https://cglapps.chevron.com/msdspds/PDS ... Format=PDF
Post by jddevel » Sat Nov 14, 2020 1:31 am
Thank you.
