TC Front Wing Support
loustaller
Post by loustaller » Sat Mar 27, 2021 9:25 am
I'm having trouble understanding how the front wing support and headlight bracket fits together. When I bolt the wing support to the chassis then try to bolt the headlight bracket thru the wing and support there is a gap between the support and bracket caused by the shoulder on the headlight bracket studs. It just doesn't seem right that the headlight bracket wouldn't fit into the slots on the wing bracket. What am I missing? Is it that way so the wing bracket is held away from the wing?
Re: TC Front Wing Support
Post by frenchblatter » Sat Mar 27, 2021 10:26 am
Difficult to understand the problem other than there is a thick rubber joint on the wing side. Fit the wing stay and the headlamp bracket is easy to fit, it's self explanatory, if you see what I mean.
ed to add this. https://www.moss-europe.co.uk/pad-set-h ... 1-048.html These take up the gap you're talking about-I think. You can get a pair from Doug Pelton at From the Frame Up (I assume you're in the US)
loustaller
Post by loustaller » Sat Mar 27, 2021 10:51 am
The gap in the circle is what's confusing me. I understand there a rubber seal on the top side of the wing under the headlight bracket, I'm questioning how the headlight bracket 'mates' to the wing/chassis bracket. Is the shoulder on the stud there to keep the bracket away from the wing? If so, mine doesn't fit very well. Why?
Post by frenchblatter » Sat Mar 27, 2021 2:23 pm
I think the rubber grommet takes up that thickness. I'll take a look on Monday, not allowed in the workshop at the moment :)
loustaller
Post by loustaller » Sat Mar 27, 2021 5:18 pm
Thanks! Please let me know.
Post by Steve Simmons » Sat Mar 27, 2021 5:23 pm
I went out and checked mine, but they are all using regular bolts, not shouldered studs. So no help from me, sorry!
loustaller
Post by loustaller » Sat Mar 27, 2021 5:35 pm
The studs on the bottom of the headlight support don't have studs with a shoulder?
Mark McCombs
Post by Mark McCombs » Sat Mar 27, 2021 5:41 pm
Mine are off currently and I can confirm they have the same studs with spacers. I suspect the rubber takes this up, and the top fit at the fender light would be the tighter of the two intersecting points between the fender and this inner support.
Post by Steve Simmons » Sat Mar 27, 2021 7:09 pm
Because mine are bolts doesn't mean that was original. As far as I know, studs are correct. Even after all these years I still find things that were done incorrectly on my TC by the previous owners.
loustaller
Post by loustaller » Sat Mar 27, 2021 7:42 pm
I now see there are 2 rubber pads used on the headlight bracket to the wing. The one on the top side of the wing where the headlight bracket sits on the wing and the one I didn't know about, the thicker one on the bottom side of the wing. I now understand what frenchblatter talked about in his response. I think it's time for another order for some needed parts. Thanks all for your input!
Post by bloodysalmon » Sun Mar 28, 2021 5:38 am
all the pictures shown on the Moss site can help Lou ... no's 5 &6 are the parts in ... https://www.moss-europe.co.uk/shop-by-m ... 36-50.html
loustaller
Post by loustaller » Sun Mar 28, 2021 9:36 am
The Moss site is where I saw there is a lower pad required. That should surely fill the gap. I've already started a list of parts I need to continue on, As I'm still in the mock up stage and the parts are in primer paint I have time for the parts delivery. No rush, just trying to have fun! Thanks again for your input.
Post by Rob Reilly » Mon Mar 29, 2021 6:10 am
My TA has through bolts rather that those studs, but I have seen this stud idea on Jaguars, and they use either a very thick large diameter washer or a cup shaped washer, the idea being to spread the load out to a larger radius and minimize damage to the body panel due to flexing of the chrome part.
