tc bellhousing Id
Rickwilson
tc bellhousing Id
Post by Rickwilson » Tue Apr 06, 2021 10:08 am
Can someone tell me how to tell a TC bellhousing from a TD bell housing. are there casting #'s on them
Re: tc bellhousing Id
Post by Ray White » Wed Apr 07, 2021 12:00 am
Hi Rick. You can always tell a TC bell housing as it will have a large chunk missing where the clutch rod exits. :lol:
Post by Steve Simmons » Wed Apr 07, 2021 8:41 am
I don't recall the exact differences, but if the clutch lever is on the left then it's definitely not TC.
Bob Grunau
Post by Bob Grunau » Sat Apr 10, 2021 7:24 am
Early 7-1/4" TC bell housing is same as TC EXCEPT for the spigot that locates the B/H to the gearbox case is smaller in diameter. The spigot is smaller on the TD to match the smaller TD Inch size ball bearing. The first motion shaft opening is also smaller. Morris 10 B/H is same as early TD. Bob Grunau
Bob Grunau
Post by Bob Grunau » Sat Apr 10, 2021 7:26 am
opps, I meant to say " Early TD " in opening line. sorry Bob
