TC seat bracket fixings
Post by Ray White » Mon May 24, 2021 7:57 am
There are seat adjustment brackets fitted to the wheel arches. On my car these appear to be countersunk but the bolts are 3/16" Whitworth with hex heads. Obviously something is not right here.
Can someone tell me if countersunk machine screws are the correct fixings ? ...and presumably chromed?
Re: TC seat bracket fixings
Post by Steve Simmons » Mon May 24, 2021 8:04 am
I believe these were originally rivets.
Post by antijam » Mon May 24, 2021 8:41 am
Post by Ray White » Mon May 24, 2021 10:34 am
Thanks guys. I missed that video (for some reason) so having the measurements for bracket location on the wheel arches is very useful. Anyway; the point is that the holes in the brackets should be countersunk (as I suspected). I didn't know about the rivets so that's another help.
Post by antijam » Mon May 24, 2021 12:13 pm
I have to admit I used countersunk screws to retain mine. Since they don't show when the trimming is done.....
....the only giveaway is from underneath in the wheel arch, where there's a nut instead of a rivet tail.
Post by Ray White » Mon May 24, 2021 1:06 pm
I can't see me taking a torch anywhere near my new body tub! (Secondly) when it eventually arrives it should be painted in primer. I don't want to mess it up if I don't have to. I shall be fitting countersunk screws and nuts.
Those wheel arch trim pieces are tricky, aren't they? I am not looking forward to doing mine. I have chosen to eschew vinyl in favour of leather. I may regret the decision if there is not enough 'stretch' in the leather.
Post by Duncan M » Mon May 24, 2021 3:39 pm
That's great that Doug sells the rivets. Always nice to have an original/unrestored example to reference. Pic of passenger side. Looks like the impact on the hot rivet was provided by someone right handed. Note the flat heads. Appears they brushed on some sort of paint, after. This is TC9866, a black car.
Rob Zucca
Post by Rob Zucca » Mon May 24, 2021 6:21 pm
The rivet can also be heated prior to sticking it in the hole. Just move fast.
Rob TC5464
Post by Ray White » Tue May 25, 2021 1:57 am
I have just received two new chrome plated adjusters with brackets that screw to the seat back. They came with special dumb bell butterfly bolts. I ordered them from Octagon Spares Dept and they are absolutely fabulous!!!!!
The wheel arch brackets will need new chrome but before that the countersunk holes need to be tidied up.
Post by Rob Reilly » Tue May 25, 2021 4:19 am
Slotted flat head screws on TA.
Post by antijam » Tue May 25, 2021 5:27 am
Interestingly Doug's video shows the bracket riveted directly to the wheel arch metal. On my '48 the brackets were originally riveted through the wheel arch padding.....
They were definitely riveted - here's the underside....
I'm not sure how secure the brackets would have been - even if the padding hadn't caught fire during hot riveting! Mind you, after 60 years of rust, they weren't going anywhere!
Post by Ray White » Wed May 26, 2021 10:21 am
Just one question. What diameter were the original rivets, please?
