oil filter canister leak
jagman2
Post by jagman2 » Tue Jun 01, 2021 4:18 am
had the joy of having my TC oil canister leak at the middle seam. short of replacing it with one of the modern
spin on units, my thought is soldering the seam. i believe this should work. anyone else have this happen and what was your solution?
cheers
Re: oil filter canister leak
Post by Tom Lange, MGT Repair » Tue Jun 01, 2021 4:28 am
There were a handful of oil filters supplied as original and as after-market, and some detailing of which you have is needed.
Tom
jagman2
Post by jagman2 » Tue Jun 01, 2021 4:52 am
here is a pic of canister. i assume it is a repro of some sort.
Post by Steve Simmons » Tue Jun 01, 2021 6:56 am
So I take it this is an original style single piece, disposable canister? I think the trouble you would have with soldering would be the oil in the seam preventing solder from sticking. You could always try crimping it down tighter. If it's only a tiny weep, I think I would live with it. If it's leaking a lot then a replacement is probably best. I am a huge fan of spin on adapters which use modern filters on them. In the long run it's a much cheaper and easier filtration solution. If you want a vintage Monaro TC filter canister, I have one for sale. But for pure ease of use, I still recommend spin on adapters.
jagman2
Post by jagman2 » Tue Jun 01, 2021 8:55 am
well, i cleaned everything up including bead blasting, and heated up the seam area to burn out any remaining oil etc,
and laid solder all way around . every thing looked good, so proceeded to clean up and do a pressure leak test with
good results. no leaks and should be good to go. will give it a good coat of paint and reinstall.
cheers
Post by Tom Lange, MGT Repair » Tue Jun 01, 2021 3:32 pm
Does the bottom unscrew for a replaceable filter element?
Post by Duncan M » Tue Jun 01, 2021 4:00 pm
People started getting rid of those original style filters back in the early 50's. Good for a car show? I used an old V8 relocation kit I had sitting around. Takes a large filter like FL-1A or PL30001 shown. Tight fit but filter never rubs. No modifications, except to "new" aluminum mount. Easy to change filter with oil change. Fill up with oil before screwing on, and I have never lost prime.
jagman2
Post by jagman2 » Tue Jun 01, 2021 4:15 pm
tom...yes the bottom screws on to the canister.
Post by Steve Simmons » Tue Jun 01, 2021 4:26 pm
Ah, that changes things. Not an original type!
Post by Tom Lange, MGT Repair » Wed Jun 02, 2021 12:18 am
What you have is an after-market replacement filter housing probably sold by Moss back in the day, when replacement sock-type filters were available. When available now, they are expensive.
The FAR better solution is to get a spin-off filter unit from Abingdon, Moss or Bob Grunau, which will not only provide much better filtering, but will encourage more frequent changing. If you want to have an original look and don't mind spending the extra money, Doug Pelton at From the Frame Up sells a spin-off filter adapter hidden inside what appears to be an original vertical filter can.
jagman2
Post by jagman2 » Wed Jun 02, 2021 2:36 am
yes, i would like to eventually get mr pelton's filter housing , but my wallet is extremely thin right now.
Post by antijam » Wed Jun 02, 2021 3:12 am
I have a conversion that accepts a modern spin-off filter.....
Externally it's indistinguishable from an original canister filter I have.
Post by Steve Simmons » Wed Jun 02, 2021 6:37 am
The spin-on filters sold by Grunau and Taras are my choice. If you paint the adapter and filter, it will fool just about anyone into thinking it's an original.
jagman2
Post by jagman2 » Wed Jun 02, 2021 12:44 pm
pardon my ignorance, but i am not familiar with Grunau or Taras
Post by Steve Simmons » Wed Jun 02, 2021 12:53 pm
Bob Grunau in Canada and Butch Taras in California both manufacture parts for vintage MGs. They also both manufacture spin-on adapters, which are functionally identical, just with some visual differences. Both are members of this forum.
Post by Tom Lange, MGT Repair » Thu Jun 03, 2021 5:23 pm
I just ordered an adapter from Butch Taras, and am very pleased with it. Strongly recommended.
jagman2
Post by jagman2 » Fri Jun 04, 2021 3:33 am
how does one get in touch with either one of these gentlemen, do they have a web site?
cheers
Post by Tom Lange, MGT Repair » Fri Jun 04, 2021 3:44 am
Butch is at mgyowner@yahoo.com
Bob is at grunaumg@gmail.com
jagman2
Post by jagman2 » Fri Jun 04, 2021 11:24 am
thank you Tom
cheers
