TC Stub Axle to Axle Movement
Koopz
Post by Koopz » Sun Sep 12, 2021 9:54 pm
I am working my way through the restoration of my TC and now onto the front axle. I am replacing the king pins etc but note that prior to disassembly there is approx 1 mm of movement up and down on the king pin between the stub axle and the main front axle.
What are the tolerances here and if too great should I insert a hardened steel shim to reduce this. If so what is the acceptable movement.
Many thanks, as usual.
Re: TC Stub Axle to Axle Movement
Post by Steve Simmons » Mon Sep 13, 2021 7:03 am
The factory specifies 0.004" between axle and knuckle. Shims to on top, thrust washer on bottom.
I wrote an article about rebuilding these for the TCMG newsletter a while back. You can see it on pages 10-11 here: http://www.tcmotoringguild.org/chassis/20MayChassis.pdf
Koopz
Post by Koopz » Mon Sep 13, 2021 10:06 am
Thanks noted
S
