side screen chrome trim
Post by Ray White » Fri Dec 03, 2021 2:06 pm
Please could someone check for me the width of the chrome trim that fits onto the side screens.
Thank you.
Rickwilson
Re: side screen chrome trim
Post by Rickwilson » Sun Dec 05, 2021 12:42 pm
I am in process of installing new side screens on my TC. width of trim is about 11.5mm
Post by Steve Simmons » Sun Dec 05, 2021 1:01 pm
I have an original set of side screens here, and they measure approximately 0.45" (varies between .43 and .52) which agrees with Rick's measurements.
TC Side Screen Molding
Post by Ray White » Mon Dec 06, 2021 2:58 am
Thanks to both of you!!
I notice that only the "spoon ends" type (TD/TF) is available and I have to say that I prefer the neatly mitred look as fitted to the TC.
I hope to be able to find an alternative that I can cut to shape but I suppose if all else fails the self adhesive stuff would suffice.
jagman2
Post by jagman2 » Tue Dec 07, 2021 4:57 am
i too prefer the miter type but had to settle for the spoon end type. some of the pieces were too short and
would come loose from the fasteners. after a lot of adjusting, at least there mounted. i still do not like the gaps
at the corners.
Post by Franz Tenbrock » Tue Dec 07, 2021 8:26 am
Hi
i got the car with simple sidescreens, not really fine
no chrome trim
mostly i drive the car without this sidescreens
but i thought some month how i can modify my sidescreens
with tax and shipping 200 Euros for a part i doesn t need
now i had some time to think about it and i will buy some alu
1.000 x 11,5 mm, Aluminium, Blank, Bohr-Kennrille
Mit Bohr-Kennrille
Vielseitig einsetzbar
Schlichtes und modernes Design
Leicht zu verarbeiten
Multifunktional
1 , 65 Euro
only a few euros for all
i will drill some holes for the screws and then i will glue this here on it
Chrom Zierleiste 12mm x 12m selbstklebend universal Auto Chromleiste Kontur DE
all togehter 20 Euros
perhaps some day i will make it a little bit more original like
Post by Ray White » Tue Dec 07, 2021 2:59 pm
Franz. An alternative is self adhesive chrome trim.
https://www.carbuilder.com/uk/search?q=chrome+trim
Post by Franz Tenbrock » Wed Dec 08, 2021 9:04 am
If you use a translator you will see that it is the same as what I want to do
I will fix the aluminium trim with the existing screws and then glue the self-adhesive chrome trim to the aluminium trim.
:lol:
