Ignition coil
Ignition coil
Post by jddevel » Sun Dec 12, 2021 6:59 am
Is there a way of checking whether the coil I have is best suited for a positive earth car. Whilst bought from the Octagon and therefore I assume OK, reading other articles I note that most generic coils are for negative earth cars. I understand that it shouldn`t necessarily make to much difference but I thought I`d check.
Re: Ignition coil
Post by antijam » Sun Dec 12, 2021 1:59 pm
All ignition coils are fundamentally the same. The only factor that suits them to either positive or negative earth vehicles is the markings on the cap. Regardless of which way the coil is connected it will still produce a spark at the plug, however the most efficient spark will depend on which way the connections are made
This article explains it more comprehensively and lucidly than I can. Although related to the MGA the data are true for any coil ignition car.
Re: Ignition coil
Post by jddevel » Mon Dec 13, 2021 1:36 am
Thank you
Re: Ignition coil
Post by Steve Simmons » Mon Dec 13, 2021 9:59 am
The only thing is which sides the primary and secondary are connected to. Supposedly that's what makes it a coil intended for one polarity or the other. I've heard that you get a slight improvement if it's connected a certain way versus vehicle polarity but I don't have any science to back that claim up. Connecting it to your car should of course be done polarity correct for best performance.
Re: Ignition coil
Post by jddevel » Tue Dec 14, 2021 12:35 am
Thank you Steve. Lots of interesting reading discovered on the net.
