Earth straps
Earth straps
Post by jddevel » Mon Jan 03, 2022 12:16 pm
On my TC I found that there was an earth to chassis strap both on the engine (bellhousing) and the gearbox prop. end. Is this unusual - I`ve never encountered it before.
Re: Earth straps
Post by Steve Simmons » Mon Jan 03, 2022 12:35 pm
To be honest, you can never have too many. Extra dash grounds aren't a bad idea, and some people also ground the distributor body.
Re: Earth straps
Post by Franz Tenbrock » Mon Jan 03, 2022 12:47 pm
so i know what to do in the next weeks
why a strap at the gearbox, there is no electric part
at the engine ok, it is necessary, starter and ignition distributor
Re: Earth straps
Post by Steve Simmons » Mon Jan 03, 2022 2:46 pm
The ground travels through the entire chassis, engine, gearbox, etc. Having a second ground connecting the engine (where all the electrical components are) ensures good flow of electrons! If the main ground is good then there's no need for a second, but if the main ground gets corroded or dirty then a second ground will take up the slack. Of course this is no substitute for keeping your grounds clean!
Re: Earth straps
Post by Franz Tenbrock » Tue Jan 04, 2022 11:52 am
Steve :oops:
you drive your car in the dirt ????
you are not cleaning and polishing it all days
some people had this cars in there garage for 60 year never driven it
they need no ground
you need two
me too
just this evening orderd a 2 day rally in April
so i have to hurry up with the new electric
Re: Earth straps
Post by Duncan M » Tue Jan 04, 2022 8:19 pm
A slick alternate grounding setup on the TC can be seen in these pics of a TC once owned by Jim Hall. Scroll through the pics. https://rmsothebys.com/en/auctions/hf17 ... ter/459668
Battery ground cable goes to the bolt through the battery box that attaches right next to the left side of makers plate. Typical. Then another battery type cable is run from that same fastener (next to makers plate) down to the bell housing bolt right next to the engine number tag.
Re: Earth straps
Post by Steve Simmons » Wed Jan 05, 2022 9:55 am
You could say that, yes. :)
Re: Earth straps
Post by Franz Tenbrock » Wed Jan 05, 2022 10:38 am
8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)
would like to drive my car in such a nature
must be perfect
wonderful pictures
thx for sharing such pictures of your TC
