TC panel warning lights.
Post by Ray White » Sat Jan 29, 2022 9:54 am
I am in the process of tidying up the panel warning lights and I need some of the small brass nuts that attach the wire.
Does anyone know what size nut is used and where I might get some. ?
Incidentally, the repros have a different thread.
Re: TC panel warning lights.
Post by Steve Simmons » Sat Jan 29, 2022 10:07 am
I don't know for sure, but I suspect they are BSF/BA. The repro is probably metric.
Post by Ray White » Sat Jan 29, 2022 3:55 pm
I would like to know for sure as I suspect they might be BA. There again, they could be BSB.?
Post by Duncan M » Sat Jan 29, 2022 9:58 pm
BSB and BSF are 55 degree Whitworth thread forms. Variations in TPI. Something that small on an electrical/instrument I suspect would be BA, but just a guess. BA is a 47.5 degree thread. BA nuts should not be that hard to find online. If it is BA and you try a 55 degree thread, or 60 degree (metric) thread that is a similar size and thread count it may screw on, but you will not be able to tighten it-- as it buggers the threads.
https://www.madmodder.net/index.php?topic=12952.0
Post by Duncan M » Sun Jan 30, 2022 4:54 pm
If it is BA and you can get a precise measurement of the stud (widest measurement) the nut would fit on, you can look on this chart for major diameter to get size. BA size 0 - 12. Ebay has most BA sizes.
Post by Steve Simmons » Sun Jan 30, 2022 6:23 pm
I never even considered BSB. Can't remember the last time I heard someone even mention them! As I recall, British Brass is used more for plumbing pipe and the like?
BA is likely right. A lot of those tiny threads are BA.
Post by Rob Reilly » Sun Jan 30, 2022 7:43 pm
I've heard of BSC cycle threads, but this is the first time I've heard of BSB.
But Smiths and Lucas stuff is usually BA threads.
I get them from British Tools & Fasteners in New York.
https://britishfasteners.com/help.html
Post by Ray White » Mon Jan 31, 2022 1:35 am
Thanks guys. I am surprised that this is not a more common question. The diameter of the stud is 9.5mm - so not on the BA table above. The nuts are quite shallow - half nuts.? and there should be two of them.
The item is threaded brass with a spring loaded plunger (that the bulb compresses).
Post by Rob Reilly » Mon Jan 31, 2022 6:47 am
If you measure in millimeters I suspect you are in a metric country.
9.5 mm = .374" so my first guess is it is probably a 3/8-20 BSF thread.
Does the thread pitch look to be about 1.25 mm?
Post by Ray White » Mon Jan 31, 2022 7:51 am
My apologies to everyone. I made an error with the size. It's NOT 9mm (of course it's not!!) It measures 4.7 mm ........so the size nut I need is 2 BA.
Sorry again......and thanks for your help!
Post by Ray White » Sat Feb 05, 2022 3:02 am
So I ordered some 2 BA 1/2 nuts (Ebay) and they have arrived. Unfortunately although quite close, they won't go on.
I don't know if the thread in the nuts is not 2BA as described or if the original thread is not BA after all.?
Post by Ray White » Wed Feb 09, 2022 3:13 am
I received some 3/16" BSF brass nuts today....and they don't fit either!!!
Post by Rob Reilly » Sat Feb 12, 2022 9:42 am
Thread identification shouldn't be this hard. I may or may not have the same lights, but they are in a box so I can easily look at them. Maybe you could post a picture of what you are doing.
Post by Ray White » Sat Feb 12, 2022 11:00 am
As previously mentioned, the repros have a different thread again...I suspect metric.
I would like to establish what the original thread should be.
Post by Rob Reilly » Sat Feb 12, 2022 2:57 pm
Well I would have put money on an electrical item being 2BA, but now I'm stumped.
I measure .181" OD and 40 threads per inch.
What is that?
I found something called 3/16-40 Model Engineer's thread here.
https://britishfasteners.com/threads-ME
It seems to be used by people who build model steam railroads.
https://journeymans-workshop.uk/baandme.php
I think that must be it, though why Lucas would use it is beyond my comprehension.
This site, which is my supplier of choice for British screws, has all the British thread charts.
Post by Ray White » Sun Feb 13, 2022 9:56 am
Many thanks, Rob. I have sourced some here in the U.K.
I would imagine they are the right nuts for the job.
Will post again when I get them.
Cheers,
Ray.
Post by Ray White » Thu Feb 17, 2022 2:38 am
Believe it or not...those are not the right nuts either!
I have now spent enough on nuts. I could have bought a new light for the money.!
I have resolved the issue in a different way. I now have a small rubber grommet acting as an insulator and being compressed under pressure allows me to get away with just the one nut..
