TC body panel fitting
Post by jddevel » Sun Apr 10, 2022 12:50 pm
Although I`ve raised this under another topic which although it has had a number of views I`ve yet to get a response I`ve started a new topic. So advice need is two things 1) what is an acceptable gap between the running board and the rear wheel arches/fenders on a TC. It`s a new tub but original running boards and arches. 2) the original bush between the rear wheel arch and petrol tank has a metal washer on one side. I failed to note on removing which side the metal washer went.
Re: TC body panel fitting
Post by Duncan M » Sun Apr 10, 2022 1:21 pm
I don't see a washer on either side of the rubber. Maybe that washer was a sort of shim? Interesting craftsmanship from the factory on the inner wheel well where the bolt that ties in that rubber. Note how the seams overlap, but a semi curcular cutout was made to accomodate the bolt head.
There was a recent discussion on the rear running board to fender gap, and there was quite a bit of variation. I am thinking it was something like less than an inch to around two inches. Not uncommon for one side to be different from the other side of the car.
IMG_1467 (1).JPG (80.94 KiB) Viewed 713 times
joel hutchins
Post by joel hutchins » Thu Apr 14, 2022 8:31 am
I restored my car, a 49 TC exu, from 1975 to 1985, before any books were written on the subject that I could find. That said The measurements I made of the body and attach points were transferred to the 2x4 substructure then the ash timbers and I started there .
The running boards were put on the body per the hole measurements I had made and they looked fine to me, a gap at the back edge but not the same on each side. I do not remember the metal piece on the tank mounting but will look.
Keep working guys, Joel.
