tc carb needle
TCTrev
tc carb needle
Post by TCTrev » Fri May 06, 2022 9:45 am
has any body come across needles stamped with ap
Re: tc carb needle
Post by Duncan M » Fri May 06, 2022 11:59 am
AP is the lean needle
ES is standard
EM is rich
Re: tc carb needle
Post by Tom Lange, MGT Repair » Sun May 08, 2022 1:11 pm
If you go to mintylamb, you can compare three different SU needles at a time. In this case, you can see how close the three needles cited above, really are, station by station.
TCTrev
tc needles
Post by TCTrev » Tue May 10, 2022 1:57 am
i have found ap needles in my carbs is it a bad thing
Re: tc needles
Post by stephen stierman » Tue May 10, 2022 2:25 am
I tried lean needles in my TC for awhile and they did not run very well, went back to standard.
Re: tc carb needle
Post by Duncan M » Tue May 10, 2022 11:44 am
I had the same experience as Stephen with lean needles.
I imagine the AP needles might be useful for a more or less stock engine at altitude. In carbureted V8's I will lean the carb at around 4,000 ft elevation. A bit more lean at 6,000 ft. You notice the difference. Not familiar with altitude tuning the XPAG in practice, as my TC driving range is from sea level to around 3,000 ft elevation.
Re: tc carb needle
Post by stephen stierman » Fri May 13, 2022 11:16 am
To be more specific they were problematic in warm weather in stop and go traffic situations. Surging and generally poor running and idle. The standard needles worked much better.
