MGTC number plate
MGTC number plate
Can anyone tell me the length of the backing plate for a TC to accommodate the two D lamps the law requires please? As mine only allows for one I`m considering having one made in stainless.
Re: MGTC number plate
If a UK number plate is 52 cm and each D Lamp is 8.5 cm that’s 69 cm. So 70 should do it.
Thank you Will had sort of "guessed" it at 70-72.
i believe FTFU has both the single and dual number plates.
Thanks Jagman2. I`m in the UK so delivery a no no. Anyway looking into getting some made in stainless- OK so not original but then nor is the car. Those available seem to be silly money for what they are.
