Oil catchment tray
Oil catchment tray
Post by jddevel » Wed Jan 10, 2024 6:02 am
Sources for the catchment tray to attach to bell housing please. Have contacted John James but covering the bases.
Re: Oil catchment tray
Post by Franz Tenbrock » Wed Jan 10, 2024 7:26 am
make it by yourself,
it is easy ;-)
if you can weld
will cost less then 3 Euro
Post by Steve Simmons » Wed Jan 10, 2024 8:20 am
There's a guy in the USA who sells them on eBay for $70, as seen here: https://www.ebay.com/itm/266575035014
Here's another ad in the UK at about the same price, but not sure how old it is: https://www.mg-cars.org.uk/imgytr/store ... rays.shtml
jagman2
Post by jagman2 » Wed Jan 10, 2024 1:25 pm
why not replace pan gaskets and front seal. much easier. and problem solved with
proper installation.
cheers
stu
Post by stephen stierman » Wed Jan 10, 2024 6:27 pm
Because the pan gaskets and the front seal are usually not the problem, it is the rear slinger that causes the major leak that this thing was designed to remedy as a stop gap band aid :D measure.
