TC Front Spring Mystery
BCBryan
Post by BCBryan » Fri Mar 29, 2024 9:58 am
I'm in the process of rebuilding the front axle for TC 6984 and was surprised to find that the arc on the two springs is quite different- see photos. The car seemed to have the correct stance when I brought it home - we have not driven her other than on and off the transport trailer. I did find missing leaves in the rear spring though.
One sources suggests that the arc of the front spring off the car should be 1.85 inches. Interestingly for these two, one is 2" under the arc and the other is 3". Which is correct?
From the overall appearance of the spring, the higher arc one seems nicer, has taper leaves and the 4 clips of the original. The lesser arced one has only 2 clips and has square cut leaves.
Re: TC Front Spring Mystery
Post by Steve Simmons » Fri Mar 29, 2024 10:04 am
One may be older than the other, or the steel has lost its temper.
You can test the springs using this data: http://www.tcmotoringguild.org/techinfo ... g-data.jpg
Post by Rob Reilly » Fri Mar 29, 2024 10:08 am
The Blower manual has spring data for all models including the TC.
Post by antijam » Fri Mar 29, 2024 1:16 pm
....and this is the data for the TC front.....
BCBryan
Post by BCBryan » Fri Mar 29, 2024 1:18 pm
Thanks All: I measured the spring leaves against the Blower data and they are both correct. It's off to the spring shop for some retempering .
Bryan.
Post by Duncan M » Fri Mar 29, 2024 4:36 pm
The TC springs are fairly easy to re-arch if someone wants to get the right and left side ride heights to match in front. Can be done (one leaf at a time) using a strongly mounted vise and some muscle, as opposed to the hydraulic press method required for bigger springs. If the springs are stamped "BERRY" then they are likely original.
