tc wheel dims
jagman2
tc wheel dims
Post by jagman2 » Fri Aug 16, 2024 6:28 am
the rims on my tc measure 4" outside. i wanted to order new tires from blockley but they
indicate the rim width max should be 3.25 for the 4,00 x 19 tires. do i have non standard rims?
cheers
stu
Re: tc wheel dims
Post by Rob Reilly » Fri Aug 16, 2024 10:06 am
Rim width is measured on the inside. Yours should be 2.5" same as mine.
They are stamped DRC 250 19
I have these radials from American Classic.
jagman2
Re: tc wheel dims
Post by jagman2 » Fri Aug 16, 2024 10:11 am
hi rob
thanks for the reply....i learned something today......i appreciate it
cheers
stu
robertscottcostello
Re: tc wheel dims
Post by robertscottcostello » Fri Aug 16, 2024 10:43 am
mws order.JPG (34.2 KiB) Viewed 2171 times
Same size as mine, 2 1/2"
I ordered my Blockleys from Motor Wheel Service. They had good prices on spinners so I ordered a full set of those as well.
4.50 x 19 Blockley Tyres (100% Rubber)
DoT plant code 0X2
TR13 Tube : 450/500 x 19 - Rubber Valve
100% Rubber Inner Tube with a Rubber Valve
Rim Band To Suit 18"-19" Wheel (100% Rubber)
Go with the Blockley inner tubes, they are very thick.
1949 TC7556
https://vintagemgchicago.com/
verbum sapientes constat pecunia
jagman2
Re: tc wheel dims
Post by jagman2 » Tue Dec 10, 2024 8:59 am
ok, i did order the bockley tires and tubes. also rebuilt the bishop steering box with new cam, peg, bearings etc.
also new steering balls and new hubs and bearings. i set toe in to 7/16". no more wandering and now fun to drive.
Re: tc wheel dims
Post by Duncan M » Thu Dec 19, 2024 9:42 am
Good to hear you got the original steering sorted out. The quick Bishop cam steering box is wonderful. Nothing quite like it. :thumbs:
jagman2
Re: tc wheel dims
Post by jagman2 » Fri Dec 20, 2024 5:25 am
ues, i too like the quick steering. reminds me of my old model T .
next project is replacing the ratty original floorboards and disintegrating gearbox cover.
cheers
stu
