XPAG Distributor
XPAG Distributor
Original distributor for XPAG engines. Model DKY4A / 40162 which is correct for MG TC or TD. All original including the good OEM points and soldered condenser. It was working when pulled many years ago but should be rebuilt, as there is too much play in the bushings. Complete from top to bottom including a TD-style clamp. This clamp will also work with TC, or swap it back to the TC micro-adjuster if desired. The little plastic insulator piece on the side is cracked and should be replaced during rebuild. $120 plus postage.
