Hub To Halfshaft Friction Welding
Kameron M
Post by Kameron M » Tue Jun 14, 2016 7:29 pm
Hello All, this is in response to my other post "WANTED - YOUR WORN OUT REAR HUBS AND OLD HALFSHAFTS!"
Here's the scoop:
I know that there is a fair bit of a wee little problem when TC halfshafts and hubs as originally designed come into play. I myself am fighting this issue now. Strangely, though, I've come into a rather interesting job, that being engineer at a company that makes Friction Welders!
If you are not familiar with the process of friction welding, the simplest case is rotary inertia friction welding- where two pieces are placed in a lathe-looking-like contraption. One is spun up to speed on a spindle that has many large flywheels attached. The spindle is then pushed forward until part contact and then a measured dose of pressure is applied. The rubbing of the two parts against each other causes a great deal of heat to be generated at the welding interface, and suddenly! The two parts in question become one. Unlike normal kinds of welding, this joint has a very distinct advantage, weld "penetration" is very deep, and the weld surface exists not just at the edge plus penetration, but over the entire contact area between two pieces.
Anywhoozle.
I have seen first-hand what these mean machines can do. They can produce forged quality joints into things with unusual geometries. They hold concentricity very well by nature. Given that our hubs are naturally cyndrillical, and the halfshafts are as well, there is limited doubt in my mind at least about the possibility of this. Also, there are a number of advantages if this works which I can think of off the top of my head.
1- Halfshaft will NEVER disconnect from hub. - No weeble wobbling, no looseness. Friction welding is the same process used to join up auto driveshafts, piston rods on heavy equipment, and jet engines.
2- Hubs less expensive to machine - No more need of central splined hole through hub, or tapered hole through hub eliminates valuable machine time. Similarly, halfshaft piece would only need one splined component to it
3- Length of halfshaft extending from hub can be very tightly controlled as a tolerance and, ref #1 - will not change, ever!
4- Assuredly, during hub removal, halfshaft will come out with hub
5- Hub design already favorable to friction welding process - The TC hub is "almost" perfect for this to happen. It has a recess built in which gives generous clearance around the wheel bearing nut. In order to make this more practical, said hole might need to be made a bit deeper, however narrower, though I'm not entirely sure, there might be enough clearance anyhow. This will be checked. The hub is also small in diameter, and could be fitted right into a spindle of one of these machines at least by size. Whether or not better tooling will need to be made to ensure the threads and splines on the outside of the hub need be protected has to be evaluated.
Long story short, I desire some used, unwanted, damaged TC hubs to do some experiments on, especially to see if making or adapting tooling for this is plausible and feasible. If it falls on its face, then the resulting prospects are some time, and a few unusable hubs and halfshafts will be toasted up in the experimentation. If it does work, then there might be a considerable future cost savings and reliability improvement I have to offer the lot of TC owners, and perhaps perhaps other cars as well.
So, if you are changing out your rear hubs, or making some new ones and screw up on the machining somehow please think on this and get in contact with me. The more inexpensive TC hubs I have to burn through without shame, the more chance I have of getting the process right.
-kam-
Re: Hub To Halfshaft Friction Welding
Post by Gene Gillam » Sun Jun 19, 2016 9:42 am
Kam, did you ever get any?
Kameron M
Post by Kameron M » Sun Jun 19, 2016 6:57 pm
Not yet. It is not to say that I don't have other projects to occupy my time with at the moment.
Spoke to some people in manufacturing about what I wanted to do. Most likely new hubs would have to be machined for this process to work anyways, it would seem. As it stands right now, there is still a need for old hubs to get the tooling right and to test to see if the tooling will hold the hub without damaging it against the forces at play and without slipping. If that can be done, then a new hub blank could be CNC machined, but without some of the more expensive parts to it, E.G. the cutout in the center of it. This would still reduce cost, somewhat, same for the halfshaft.
As far as I can tell, the overall price for a set of friction welded hubs and halfshafts would probably be about the same as the standard replacement, but still with the structural advantages of friction welding present.
It would seem, though that the best way to re-use old hubs would be the machine taper conversion, but that is not to say I'm giving up, just because I'm having taper fit halfshafts sent to me.
Speaking of which, does anyone know off the top of their head what the metallurgy of the hubs and halfshafts are? I think the hubs at least are just a mild low-carbon steel from the look and feel of them, but I'm none too sure.
Post by Duncan M » Sun Jun 19, 2016 8:37 pm
Kam-
Probably hardened low-carbon steel for the half shafts. Doesn't welding normally make hardened steel brittle?
A link discussing half shaft for TD's from original to a couple of different replacement parts over the year's, may be of interest. http://www.ttalk.info/HalfShaftReplacement.htm
Appears even the TD original half shaft is of somewhat unknown material and hardening process.
Roger Furneaux lists the steel as EN24T on his replacement TC half shafts. Near top, page 3
http://www.mg-cars.org.uk/imgytr/pdf/madmetrics.pdf
or-
Bob Grunau has tapered, maybe he could tell you something about the steel? He makes the front stub axles for TC's, etc. A link w/ contact info: http://www.ttalk.info/Grunau.htm
