Hub and spindle threads
- timandgerda
Just to be sure - Spindles, right hand side = right hand thread, left hand side = left hand thread.
Hubs - right hand side = left hand thread, left hand side = right hand thread?
Cheers
Tim.
Cheers
Tim.
Re: Hub and spindle threads
Yes, the threads of (front) spindle nut and knock off are opposite each other (per side) .
- timandgerda
Thanks Duncan. I have found several book references that agree but just wanted to check with those of you that have actual cars!
Trick I have always used is when using the hammer to tighten the wheels you always hit the top of the spinner to the back of the car.
- dirk w dondorp
Great Tip Ed, I always forget which is which.
Thanks
Dirk,- waiting for the spring to come in Hamburg.
Thanks
Or that the spinners tighten opposite to the wheel rotation. Roll the car forward, spin the knockoff backward. Or another way, roll the wheel forward and hold the knockoff still, and it will tighten.
Also, spindle nuts are opposite of knockoffs.
