I'm trying to identify which of these (if either) is a correct TA reflector. The primary differences I note are:
1) One reflector has the pivot point visible from the front while the other is hidden
2) There are clips riveted into the pivot on one of them, perhaps for wiring
2) The shape of the bracket where it attaches to the outer rim is completely different
3) The fuse holder is in a different place
4) The shape of the area around the fuse holder is slightly different
5) The dimples around the rim are in different positions
Any ideas if one of these is TA, and what the other might be from?
Dipping Reflectors
